Differential Oscilloscope Probe PCB
What is it? Caution -This is a PCB Only with a lot of surface mount soldering of fine pitch parts This circuit uses two LT6268 high-frequency amplifiers to realize a fully differential oscilloscope …
Read More…Sometimes you need to test circuits that can't be connected through your scope chassis to earth ground. Commercial differential scope probes are extremely expensive.
This differential oscilloscope probe is based on a Linear Technology application note. The design uses LTC6268-10 op amps which are 4GHz FET input operational amplifiers with extremely low input bias current and low input capacitance.
Part 1 of 4 part Video series that describes my failures along the way to the final success. This was a difficult board to get the layout just right.
Enter your email address if you'd like to be notified when Differential Scope Probe (PCB Only) can be shipped to you:
21 Reviews | 883 Orders
