6 Position Eurorack Power Card (PCB Only
What is it? This is a PCB only. You supply the parts to build the card. 6 Eurorack 16 pin connectors In/Out 5mm Terminal Blocks (on both ends) for daisy-chaining cards Alternately, wires could be so…
Read More…This is a PCB only. You supply the parts to build the card.
I needed some small Eurorack Power cards. This card is small enough to extend the power on an existing rack. It's easy to assemble.
There is a price break for qty 2 card sets. If you order 2 cards, they ship as a panel that needs to be snapped apart. The cards separate easily from each other since they are V-scored. It's just a bit easier to ship them as panels.
Enter your email address if you'd like to be notified when Eurorack Power Card (PCB Only) can be shipped to you:
1 | $8.00 |
2+ | $6.00 |
21 Reviews | 883 Orders
