Card that allows 3.3V and 5V devices to be easily connected to the Raspberry Pi.
This board is modeled on the Arduino Sensor Shields, also known as GVS shields. Arduino Sensor Shields bring out the pins of the Arduino to GVS (set of Ground, Voltage and Signal) pins. Unfortunately…
Read More…This board is modeled on the Arduino Sensor Shields, also known as GVS shields. Arduino Sensor Shields bring out the pins of the Arduino to GVS (set of Ground, Voltage and Signal) pins. Unfortunately, the Raspberry Pi can't work with the same 5V GVS sensors and devices as the Arduino since the Raspberry Pi has 3.3V I/O.
The RPIO-TINY-2 card allows the Raspberry Pi to communicate with the same 5V sensors by performing voltage translation from the 3.3V of the Raspberry Pi to 5V.
Features
Raspberry Pi I/O lines
All of the Raspberry Pi I/O connections are brought to GVS connectors. This is:
Enter your email address if you'd like to be notified when Raspberry Pi 5V Sensor Conn. Card (RPIO-TINY-2) can be shipped to you:
21 Reviews | 883 Orders
$25.95
$9.95
