Card for the Raspberry Pi Pico that can run MMBASIC with VGA, Sound, Keyboard, SD Card, 32-bit GPIO
Designed by Land Boards, LLC in United States of America
PCB Only option is a PCB only, not a kit of parts. You supply the parts. This is Version 2 of this card. Version 1 of the card is here. It has 16-bits of I/O port expansion. Version 3 of the card is…
Read More…PCB Only option is a PCB only, not a kit of parts. You supply the parts.
Version 3 of the card is here. It is designed to fit into a standard extruded aluminum enclosure.
Adapter card for the Raspberry Pi Pico running MMBASIC with VGA, Sound, PS/2 Keyboard, SD card, and 32-bits of Digital I/O.
The "PCB Only" option is not a kit of parts. It is the PCB only.
It's really cool with a bit of retro and modern together in one design. And the Raspberry Pi Pico is inexpensive and widely available.
Based on the PicoMiteVGA reference design but adds two 16-bit Digital I/O Expanders for 32-bits of Digital I/O. Note that the pinout used in the MMBASIC build is different than the reference design from the Pi Foundation.
The card uses mostly through-hole parts with only 2 Surface Mount parts. The SD connector is easy to solder and the keyboard 5V to 3.3V level shifter is not difficult to solder (it's an SOIC-14). Picture shows 1/8W resistors but 1/4W resistors fit the footprint.
The Pico is not included. It is widely available (Digikey, Adafruit, others).
Enter your email address if you'd like to be notified when Raspberry Pi Pico Card with VGA, Sound, Kbd Ver 2 can be shipped to you:
21 Reviews | 888 Orders
