Card for the Raspberry Pi Pico that can run MMBASIC with VGA, Sound, Keyboard, SD Card, 16-bit GPIO
Designed by Land Boards, LLC in United States of America
There are three versions of this card on Tindie. This is Version 1 of the three. Version 2 of the card is here. Version 2 has 32-bits of Digital I/O on a DB-37 connector. Version 3 of the card is her…
Read More…There are three versions of this card on Tindie. This is Version 1 of the three.
Version 3 of the card is here. It is designed to fit into a standard extruded aluminum enclosure.
Adapter card for the Raspberry Pi Pico running MMBASIC with VGA, Sound, PS/2 Keyboard, SD card, and 16-bits of Digital I/O.
The "PCB Only" option is not a kit of parts. It is the PCB only.
It's really cool with a bit of retro and modern together in one design. And the Raspberry Pi Pico is inexpensive and widely available.
Based on the PicoMiteVGA reference design but adds a 16-bit Digital I/O Expander. Note that the pinout used in the MMBASIC build is different than the reference design from the Pi Foundation.
The card uses mostly through-hole parts with only 2 Surface Mount parts. The SD connector is easy to solder and the keyboard 5V to 3.3V level shifter is not difficult to solder (it's an SOIC-14). Picture shows 1/8W resistors but 1/4W resistors fit the footprint.
The Pico is not included. It is widely available (Digikey, Adafruit, others).
The Rev 1 board (sold prior to 22 June 2022) has the I2C connections swapped to the I2C port expander. It requires two etch cuts and two wire jumpers per the I2C rework instructions. This has been corrected in Rev 2 cards.
Enter your email address if you'd like to be notified when Raspberry Pi Pico Card with VGA, Sound, Keyboard can be shipped to you:
Chris | July 10, 2022
David | July 8, 2022
21 Reviews | 888 Orders
