Multicomp compatible FPGA base board (PCB Only)
This is for a PCB only. You supply the parts. The BOM is attached to the design file link below. The SRAM and FTDI chip require soldering Surface Mount Fine Pitch parts. Current PCB is now black (as …
Read More…This is for a PCB only. You supply the parts. The BOM is attached to the design file link below. The SRAM and FTDI chip require soldering Surface Mount Fine Pitch parts. Current PCB is now black (as of 2021-June).
Full MultiComp Support of classic 8-bit Retrocomputers
Supports Cyclone IV or Cyclone V FPGA Cards by QMTECH
1MB SRAM
VGA connector
PS/2 connector
FTDI USB to serial converter
SD or SDHC Card
2x6 Header
Power card from either FPGA card connector or USB power
50-pin I/O Connector
95x95mm form factor card
4x 6-32 mounting holes
Low Profile
Enter your email address if you'd like to be notified when Retrocomputer FPGA Card - PCB Only (RETRO-EP4CE15) can be shipped to you:
21 Reviews | 883 Orders
$4.90
$4.90
$4.90
$4.90
