3-digit 1.5" Red 7-Segment Display surrounded by 18 addressable LEDs
Designed by LEK Electronics in Indonesia
A red 3-digit 1.5 inch 7-segment display surrounded by 18 addressable LEDs. Use it to show arcade game scores or important counts. Colorful LEDs can be used to highlight events or produce eye-catchi…
Read More…A red 3-digit 1.5 inch 7-segment display surrounded by 18 addressable LEDs. Use it to show arcade game scores or important counts. Colorful LEDs can be used to highlight events or produce eye-catching animations.
Cascade multiple display boards together using the same processor IO pins.
Drop-in compatible with some existing arcade games (7-segment only).
Consider each display digits as being a 24-bit version of the 74HC595 shift register. Writing bits into this register and then latching the data in is enough to turn display segments on or off. If another display is daisy-chained, then just write another 24 bits before latching the data.
Enter your email address if you'd like to be notified when Arcade Aura 3 can be shipped to you:
$5.20
$2.00
$13.50
$2.00
$8.50
$13.85
