This module disables the ignition for a gas engine using one R/C receiver channel and includes a navigation light controller
The E2314 Ignition Switch Light Controller is an opto-isolated ignition shutoff switch with a navigation light controller for gas powered R/C aircraft. The ignition switch is turned off if the servo…
Read More…The E2314 Ignition Switch Light Controller is an opto-isolated ignition shutoff switch with a navigation light controller for gas powered R/C aircraft.
The ignition switch is turned off if the servo pulse period exceeds a threshold after a 2 second delay. The ignition is switched off at the servo pulse period halfway point and a polarity jumper selects between decreasing servo pulse (jumper on) or increasing servo pulse (jumper off).
The switch is rated at 12Amps, 30V while the module is powered from a 4V to 12V servo channel from the receiver.
The light controller provides both static red & green wingtip and white & white wingtip and red tail strobed navigation light outputs powered through current limiting resistors matched to red, green, and white LEDs for 20mA @ 5V.
The strobed outputs are switched on with the ignition for a realistic aircraft look. LEDs are easily connected to the paired male pins on the board periphery using 2 pin JR style connectors.
LED cables are available separately at custom lengths.
Enter your email address if you'd like to be notified when E2314 RC Aircraft Ignition Switch Light Controller can be shipped to you:
$24.99
$89.99
$24.99
$27.00
$89.00
$75.00
$19.95
