Power distribution board including rail splitter with +/- outputs, USB 5V, and adjustable power supply.
The E2980 Power Distribution board eases the problem of connecting adapters to prototype circuits, and also provides the most common options for powering analog circuits with a split supply as well…
Read More…The E2980 Power Distribution board eases the problem of connecting adapters to prototype circuits, and also provides the most common options for powering analog circuits with a split supply as well as providing for logic or other requirements. Included are a rail splitter with +/- voltage outputs, a USB derived 5V, and a selectable output voltage regulator providing commonly used 3.3V, 5.0V, and adjustable voltage options between 1.2V to 28V. The rail splitter generates an artificial ground halfway between any DC input voltage 6V to 36V. The outputs can be interconnected to obtain different grounding or voltages.
Enter your email address if you'd like to be notified when E2980 Power Distribution Board can be shipped to you:
$24.99
$89.99
$27.00
$24.99
$89.00
