E3002 Single Wire Serial LCD Interface for 1x8 to 4x40 LCDs, easy to use 1 byte for data or 2 bytes for instructions.
The E3002 Single Wire Serial LCD Interface allows standard alphanumeric LCDs from 1x8 to 4x40 sizes to be easily controlled with a single serial pin using only single bytes for data and two for instr…
Read More…The E3002 Single Wire Serial LCD Interface allows standard alphanumeric LCDs from 1x8 to 4x40 sizes to be easily controlled with a single serial pin using only single bytes for data and two for instructions. All LCD timing is handled by the E3002. This is accomplished using a command set compatible with the HD44780 and variant LCD controllers. Non-standard commands and delays are easily handled with special instructions. The E3002 is compatible with both 3.3V and 5.0V LCDs using a jumper. A low dropout voltage regulator ensures proper logic levels to the LCD.
Enter your email address if you'd like to be notified when E3002 Single Wire Serial LCD Interface can be shipped to you:
$24.99
$89.99
$27.00
$24.99
$89.00
$16.99
