This seller is taking a break. Sign up below to get an email when they're back!
What is it? This is a LoRa Modem on an TTGO T-Internet-PoE ESP32 board. It is currently used for an APRS iGate for LoRa APRS. Why did you make it? Some time ago I had the issue that the current imple…
Read More…This is a LoRa Modem on an TTGO T-Internet-PoE ESP32 board. It is currently used for an APRS iGate for LoRa APRS.
Some time ago I had the issue that the current implementations for LoRa APRS are just running on Raspberry Pi. The Raspberry Pi is a good platform, but it is still too expensive in my eyes as an iGate can also run on one of the cheep ESP32 boards. So I started to develop a iGate Firmware for the ESP32 LoRa boards. After some time there was the need for an ethernet board.
It is running more stable than the WiFi versions and is completely open source/hardware.
You will get the LoRa modem board in a kit form. It is including everything which can be soldered on the PCB, like:
You can order a separately screw set which will include:
IMPORTANT: The TTGO T-Internet-PoE board is NOT included in the kit! You have to order it by yourself via Aliexpress or Tindie from Lilygo.
There are still parts which you have to order:
This two items can be easily ordered on Aliexpress.
Enter your email address if you'd like to be notified when LoRa on PoE ESP32 Board can be shipped to you:
$42.00
$3.90
