32 Channel Thermocouple reader and 8 Relays controlled with ESP32
Designed by Akio Sato in Azerbaijan
What is it? it is for thermal chamber to get thermocouple readings from up to 32 points and 8 relays to control it uses high accurate 32 MAX31850KATB+ K-Type thermocouple reader with onewire commun…
Read More…it is for thermal chamber to get thermocouple readings from up to 32 points and 8 relays to control
it uses high accurate 32 MAX31850KATB+ K-Type thermocouple reader with onewire communication makes the coding super simple
Used for thermal vacuum chamber as Data acquisition and control unit
32 thermocouple reading capability with easy to program with micropython on ESP32
it comes with firmware which prints out the Thermocouple data through USB port.
Enter your email address if you'd like to be notified when 32 channel Thermocouple reader can be shipped to you:
Ships in 2 business days with EMS (3-7 business days) shipping world wide
$26.36 $32.95
$16.76 $20.95
$70.00
