High Current Power Switch with ON/OFF button .(Up to 100A continuous current)
Designed by Akio Sato in Azerbaijan
What is it? High Current Power Switch. Up to 100A Why did you make it? Designed for big drones to turn ON/OFF the drone with a power switch. What makes it special? very light weight, super small and…
Read More…High Current Power Switch. Up to 100A
very light weight, super small and high current.
On/Off switch designed with revers logic, in that case even the switch malfunctions for some reason, system will be powered.
Weight: 15g
Cells: 2 versions available 40V input voltage, and 60V input voltage
Continuous current draw: 100 A
Switch: push button switch with fixation
Connector for switch: JST,SM04B-GHS-TB(LF)
Size : 65mm x 25mm
Note: it comes with Switch and 4 pins cable
Enter your email address if you'd like to be notified when High Current Power Switch with ON/OFF button can be shipped to you:
Ships in 2 business days with EMS (3-7 business days) shipping world wide
$7.95
$1.00
$2.00
