This custom Raspberry Pico breakout allows plug-in compatibility with many common modules
Designed by Low Budget in United States of America
This is a semi-customized Raspberry Pico breakout board with the GPIO pins arranged for different modules to plug in directly without jumper wires. Designed around the ssd1306 0.96" OLED display as t…
Read More…Available in two versions; a compact version and a deluxe version with extra features.
Supports direct plug in / soldering installation of (but not in any way limited to):
Features:
PCBs are available as well as separate parts kits. The parts kits are slightly different for the compact and deluxe version Pico breakout PCB so be sure to order the correct one. Kits have pre-installed 0805 SMT LEDs and current limiting resistors. Also included with the kit:
Note: 5v is only available when using USB power; 3.7v on VSYS is only available when using battery power.
Enter your email address if you'd like to be notified when Raspberry Pi Pico Multipurpose Breakout Board can be shipped to you:
29 Reviews | 1,323 Orders
