The Super 8 bit is a new hand assembled game console that can play all your favorite NES and Famicom game cartridges.
$24.99
LAST ONE v2.5 Super 8 bit will soon be sold out! The v3.0 Super 8 will still be available for a while. By using the original CPU and PPU chips, you get pixel-perfect gameplay and 100% compatibility. …
Read More…LAST ONE
By using the original CPU and PPU chips, you get pixel-perfect gameplay and 100% compatibility. The Super 8 bit has video, audio, and reliability improvements over the original Nintendo systems in a compact form factor.
The Super 8 bit was the very first aftermarket NES console to work using original hardware CPU and PPU chips when v1.1 was originally sold over 2 years ago. A lot has improved since then! The motherboard has seen 8 revisions to date.
The original front loader system had issues with the lockout chip and ZIF cartridge connector. The original top loader system only has poor quality RF video. All original systems had some form of region lock for both games and accessories.
Emulator based consoles cannot mimic the original system's particular traits like flicker and slowdown. These consoles often don't support homebrew games and depend on firmware updates to improve compatibility. These consoles support very few accessories and don't work with light guns or R.O.B.
Imported $20-$80 clone systems rely on a poorly designed ASIC that has sound and compatibility issues. Certain sounds play at the wrong pitch and many games have glitches or don't work at all. These consoles often don't work with many NES accessories and usually have very cheap construction.
Compatible with NES accessories: Zapper, R.O.B. Robot, Power Pad, 4 Score.
Compatible with Famicom accessories: Zapper, Famicom Disk System, 3D Glasses, Family Basic Computer, 4 player adapter.
The Super 8 bit's circuit board wasn't designed as an afterthought to a fancy casing, it was designed first with optimal layout of components in mind. The board has top and bottom ground planes in a thick 1.5oz finish. All PCB components are through-hole hand soldered and DIP package ICs are used when available. The system consists of 3 separate circuit boards: the motherboard, the controller port board, and the NESRGB. These boards plug into each other for easy disassembly.
The Super 8 bit's case was designed after the main PCB design was complete. It's quality 14 gauge 6061 aluminum with glossy white powdercoat finish. It has an efficient 3 piece design that allows easy disassembly. Plenty of room for future modifications, such as HDMI NES kits. Case measures 6-3/4in x 5-3/4in x 1-3/4in.
I've worked very hard making this the best NES console possible and do everything within reason to make sure my customers are satisfied. It's for the NES enthusiast looking for an authentic gameplay experience without the annoyances of the original systems. Each motherboard is individually serial numbered.
Nearly lag-free component video can be obtained by purchasing the Retrovision Component Video Cable (scheduled for release this summer http://www.hdretrovision.com ) or by installing this kit from the maker of the of the NESRGB: http://etim.net.au/shop/shop.php? crn=203&rn=549&action=show_detail
HDMI can be obtained by using a Sega Genesis 2 SCART cable to connect to an aftermarket scaler such as the XRGB mini.
The Super 8 outputs stereo sound with no mixing between channels. If preferred, mono audio can be obtained by using a RCA audio Y cable.
Composite and S-Video are output in 60Hz NTSC format only.
I decided not to include cables, controllers, games, etc. because they would either be cheap & low quality or add significant cost to the system if quality accessories were included.
William | July 22, 2015
29 Reviews | 1,323 Orders
$139.00
$42.00
