Dual Voltage Controlled Amplifier (VCA) Eurorack module
Designed by LRR Audio in United States of America
What is it? This Eurorack module contains 2 JFET based voltage-controlled amplifiers (VCA) in a 4 hp module. Each VCA has signal in, signal out, control voltage input, and a DC offset control knob. …
Read More…This Eurorack module contains 2 JFET based voltage-controlled amplifiers (VCA) in a 4 hp module. Each VCA has signal in, signal out, control voltage input, and a DC offset control knob.
VCA’s are a core component in synths. They’re commonly used in conjunction with an envelope generator for shaping sounds.
Inputs and outputs are DC coupled allowing multiple CV signals to be combined for tone synthesis. The control voltage provides exponential gain response. The inputs and outputs are buffered using fast professional audio grade op-amps to maintain signal integrity and performance.
Enter your email address if you'd like to be notified when JVCA Eurorack Module can be shipped to you:
$27.99
$71.99
$126.99
$19.79 $21.99
