A FPV VRX Dock to fix your VRX in an external bay
Designed by Maelremrem.xyz in FranceNo shipping info available.
What is it? A FPV VRX Dock to fix your VRX in an external bay so you can get a better signal. Very useful in long range situations. Why did you make it? To put the VRX in an external bay so you can g…
Read More…A FPV VRX Dock to fix your VRX in an external bay so you can get a better signal. Very useful in long range situations.
To put the VRX in an external bay so you can get a better signal for your FPV feed.
I wanted to make it very cheap
You need to buy the components yourself (marked on the pcb, banggood or aliexpress). I only provide the switch, the VRX connector, the jack connectors and the dc plug connector.
I am independent. I promote Culture FPV as a member of this team. My products have no links with them.
You will need a 5V Bec. I use a Matek Systems Micro BEC 6-30V to 5V one. You can find them on Banggood for pretty cheap.
You will need a cable jack 4 poles (trrs) to connect to you FPV Goggles
The STL Files are available here : Thingiverse
Enter your email address if you'd like to be notified when FPV VRX Dock can be shipped to you:
$13.00
