This simple PCB is used to remove a part of the hassle of the wiring of the MaxMix Project
Designed by Maelremrem.xyz in France
What is it? This simple PCB is used to remove a part of the hassle of the wiring of the MaxMix Project. Why did you make it? On the MaxMix you have to use a PowerBus and too much cable for my taste, …
Read More…This simple PCB is used to remove a part of the hassle of the wiring of the MaxMix Project.
On the MaxMix you have to use a PowerBus and too much cable for my taste, with this the only cable you need are for the oled display, the led ring and the rotary encoder. Just cut some lenght of some dupont wire and solder them onto the pcb (for the led ring solder them to the led ring instead of the pcb).
Get the remixed file for the 3D Prints. The original will not work. PrusaPrinters
Enter your email address if you'd like to be notified when MaxMix Simple PCB can be shipped to you:
