MKS DLC32 Mainboard Controller 32bits GRBL CNC Offline Control Board DLC 32
Sold By Maker's Cave
What is it? MKS DLC32 motherboard kit is an offline engraving master control kit developed for desktop engraving machines. The motherboard uses the ESP32-WEOOM-32U module, which embeds a dual-core 32…
Read More…MKS DLC32 motherboard kit is an offline engraving master control kit developed for desktop engraving machines. The motherboard uses the ESP32-WEOOM-32U module, which embeds a dual-core 32-bit high-speed MCU with a clock up to 240Mhz. The hardware is equipped with 32-bit high-speed ESP32 module, integrated WIFI function, and directly drives a 3.5in touch color screen, the performance is very powerful. The module has a built-in 8M byte Flash Memory chip, which provides effective protection for more application scenarios. The mounting holes and board size of MKS DLC32 are compatible with MKS DLC and it can also be used with GRBlaser and Lightburn PC software. Precise positioning and high precision carving. Repeatable circular engraving
Specification: Size: approx 9x7cm/3.54×2.75in Material: PCB Module: ESP32-Wroom-32U(8M Flash) Flash Memory: 8192Kybts RAM-: 520Kbytes MCU: Dual Core 32 Bit Chipset: ESP32-D0WD-V3 Stepper Driver: A4988 Aolt:12V-24V
The Older boards need to be always connected to a host computer in order to perform laser engraving/cutting. This motherboard allows the machine to work in stand-alone mode. the ESP3D service on the board also allows the motherboard to be controlled over WIFI and an android/ios app allows you to engrave via your phone as well.
The MKS DLC32 and TS35 allow offline control of your laser engraver or CNC machine. You can save the .nc or .gcode file on your sd card and print from that SD card multiple times without dealing with another host machine.
Enter your email address if you'd like to be notified when MKS DLC32 Offline Controller for Laser Engraver can be shipped to you:
$64.00
$105.00
$95.00
$89.99
