A fun soldering kit for beginners - Makes an excellent gift
Designed by Maker's Corner in ThailandThis seller is taking a break until Sept. 30, 2025. Sign up below to get an email when they're back!
$28.99
$8.79
$17.99
Here is a fun project for beginners. It’s a soldering kit that will take about an hour for a beginner to build (less if you’re an experienced solderer). It’s comes in 2 versions, one is designed to p…
Read More…Here is a fun project for beginners. It’s a soldering kit that will take about an hour for a beginner to build (less if you’re an experienced solderer). It’s comes in 2 versions, one is designed to plug into a Raspberry Pi, the other plugs into an Arduino. It will take a few minutes to program the Raspberry Pi or Arduino and then the project is ready to show to your friends.
There are three LEDs that can be controlled in whatever sequence you program. There is a small music chip with piezo speaker that will play Jingle Bells when you send it a ‘start’ signal. Then there is a photo-sensor to detect when you pass your hand overhead. Passing your hand over the sensor starts the light and sound show.
1-4 | $7.99 |
5-9 | $7.49 |
10-19 | $6.99 |
20+ | $6.49 |
$4.97 $9.95
$24.99
$18.99
