This seller is taking a break until Sept. 30, 2025. Sign up below to get an email when they're back!
$199.00
$44.99
Do you need to practice your soldering skills? Start with "The Face", put it on your bench, when someone talks it looks at them. "The Face" soldering kit provides novice and intermediate electronics …
Read More…Do you need to practice your soldering skills? Start with "The Face", put it on your bench, when someone talks it looks at them. "The Face" soldering kit provides novice and intermediate electronics enthusiasts with the opportunity to practice their soldering skills.
It is recommended that novices start with the controller board as this is the easier of the 2 boards to solder. Once the soldering is completed assembly takes about 10 minutes.
"The Face" operates from any 5V USB power source. A mini USB cable is required (not included). "The Face" has seven facial expressions which change depending on where the sound is coming from and how loud the sound is.
Facial Expressions
Click on the Documentation link below to see the instructions, schematic and board layout files.
1-4 | $24.99 |
5-9 | $23.49 |
10+ | $22.99 |
Kaye | Oct. 29, 2021
