Light Bar 93 LEDs, Color Organ, Level Meter, Chaser, Sound Music Light Show, LED Controller PWM 4 Channel - HomLiCon LCH4BAR_93
4 Channel Light Bar PWM Controller with Remote Control – HomLiCon LCH4BAR_93 Designed to control groups LED - Easily switch between the ten pre-stored groups of different levels for all channels. - L…
Read More…Designed to control groups LED - Easily switch between the ten pre-stored groups of different levels for all channels. - Light Show, automatic color organ with digital division of the bandwidth in 4 range: LF 50 - 200Hz , MLF 200Hz - 1kHz , MHF 1 - 7kHz, HF 7 - 14kHz. - Voltage up to 15V and current up to 1A per channel.
Technical Specifications | |
Number of Channels | 4 |
Supply voltage | 12V DC (12−15V DC) |
Maximum output current per channel | 1A |
Maximum total output current | 4A |
PWM steps for each channel | 110 |
Color Organ bandwidth | LF 50−200Hz , MLF 200Hz−1kHz , MHF 1−7kHz, HF 7−14kHz |
Line-in Nominal level | 0.3V / 0.15V RMS |
Mic-in range of sound level | 60-120dB |
Dimensions LCH5T | 290 x 35 x 10 mm |
Dimensions Remote | 85 x 40 x 7 mm |
Enter your email address if you'd like to be notified when Light Bar LED Color Organ - HomLiCon LCH4BAR_93 can be shipped to you:
1 | $69.00 |
2+ | $64.00 |
$54.00
$47.00
$79.00
$34.00
$74.00
$42.00
$74.00
$124.20 $138.00
