A portable LED driver board for your Bike or Wearables
Designed by MCQN Ltd in United Kingdom
My Bike's Got LED is a portable LED driver board for WLED projects to drive individually addressable LEDs at 5V from LIPO batteries. The design is based on our My Baby's got LED board but for use whe…
Read More…My Bike's Got LED is a portable LED driver board for WLED projects to drive individually addressable LEDs at 5V from LIPO batteries. The design is based on our My Baby's got LED board but for use when you need to run off battery power.
It still has two level shifted data channels for driving two strips of lights but we've made some changes to make it more suitable to portable applications. We're using an ESP32 C3 mini module to give access to more of the WLED features. There are enough GPIO's broken out via headers to allow you to connect an I2C audio input for sound reactive lights for example.
It also incorporates a battery charging circuit over USB which can be used to provide input for a secondary battery if you need your lights to run for longer. Just plug in a power bank and set off on that epic ride knowing you're bike will still be sparkling even if you've hit the wall. The battery management chip also provides 2.5 amps at 5V to power your LED strips.
Being an ESP device there is WIFI access so you can easily set new WLED effects via your phone. We've made this board for our bikes but it could be used anywhere you need WLED unplugged.
The full kit comes with 99 individually addressable RGB LED Lights
Our base kit includes:
This kit comes with everything you need to get yourself set up and ready. This includes:
Board, Lights, Battery, Bag and Velcro ties.
If you have any questions about the board or your use-case, get in touch with us at mcqn. We're not very good salespeople so are often happy to chat even if we don't think you'll buy a board.
"If your bike is looking dark I feel bad for you son, I got 99 lights when the switch is on."
Enter your email address if you'd like to be notified when My Bike's got LED can be shipped to you:
