It is an equatorial wedge that fits in between the tripod and the motorized mount to allow an equatorial alignment of the telescope.
Designed by MederosCNC in UruguayNo shipping info available.
**This wedge will allow you to perform polar alignment of your Celestron SLT scope! It is designed to enable long-exposure piggy-back astroimaging with the Maksutov SLT telescopes made by Celestron. …
Read More…**This wedge will allow you to perform polar alignment of your Celestron SLT scope!
I manufacture this stiff yet lightweight equatorial-mount wedge using aluminum extrusion and steel shaft parts achieving a total weight under 2Kg (aprox. 4Lb).
It is adjustable for latitudes of 0 to 90º with engraved scales on the sides and incorporates fine adjustment knobs for Azimuth and Latitude adjustment. **
This wedge specifically fits Celestron SLT tripods and Celestron SLT scope mounts, it does not directly fit SE mounts or other mounts made by Celestron. I can prepare special adapters to fit this wedge on other mounts and tripods of similar size, just ask! Photos show a NexStar 127SLT Maksutov telescope mounted on this wedge using a standard SLT tripod. The wedge is fixed to tripod with a center 1/4" bolt and holds the scope mount with another center 1/4" bolt. CNC machined from 6061 anodized aluminum and 1045 steel.
Please take into account that all the accesories I sell on Tindie are my own design and make. Equatorial wedges in particular are fabricated on request and although I keep pre-machined parts it takes some days to prepare each one after order is placed.
Enter your email address if you'd like to be notified when Equatorial Wedge for NexStar SLT Telescopes can be shipped to you:
