Learn the basics of electronics and Arduino programming with ease with this simple but well-crafted Arduino Uno shield.
The ultimate all-in-one Arduino education suite has arrived! Designed by an electronic engineer and teacher, this Arduino Uno shield is perfect for introducing students to the world of electronics an…
Read More…The ultimate all-in-one Arduino education suite has arrived! Designed by an electronic engineer and teacher, this Arduino Uno shield is perfect for introducing students to the world of electronics and Arduino programming.
Featuring starter-type electronic components such as LEDs, buttons, buzzer, potentiometer, LDR light sensor, RGB LED and an analog temperature sensor called MCP9700, as well as mini servo and I2C OLED display connections, this well-crafted shield is the perfect all-in-one Arduino education tool.
PandaShield Core is easy to use and provides a comprehensive learning experience. It is designed to help students learn the basics of electronics and Arduino programming by allowing them to experiment and build their own sketches. The LED lights, buttons, buzzer, and sensors make it easy for students to create programs that respond to the environment.
This well-crafted shield is designed to make learning electronics and programming easy and fun. Whether you're a student, teacher, or hobbyist, our shield provides a hands-on learning experience that will unlock your creativity and teach you the fundamentals of Arduino.
The six 5mm LED lights on our shield can be used to create a variety of visual effects, and the three buttons allow for user input in your projects.
The potentiometer and LDR light sensor provide an excellent opportunity for students to learn about analog input. They can create projects that adjust the brightness of the LEDs based on the amount of light in the environment or control the volume of the buzzer based on the position of the potentiometer.
The RGB LED adds a touch of color to the projects and allows students to experiment with different colors and color combinations. They can create projects that change color based on the temperature or that react to sound or movement.
The MCP9700 analog temperature sensor is an excellent tool for teaching students about temperature sensing and control. They can create projects that adjust the temperature based on the readings from the sensor or that respond to changes in temperature in the environment.
In addition to these components, our shield also includes connections for a mini servo and I2C OLED display that provide even more opportunities for experimenting. The mini servo can be used to control small motors and create moving parts in your projects, while the I2C OLED display allows you to display text and graphics for a more interactive experience.
In addition to its educational focus, our shield is also built to last. We use only high-quality components and materials in its construction, ensuring that it will withstand repeated use and abuse in a classroom setting.
Overall, this well-crafted all-in-one Arduino education suite is the perfect tool for teaching students the basics of electronics and programming. It is easy to use, provides a comprehensive learning experience, and allows students to experiment and build their own projects. Whether used in a classroom setting or for individual learning, this shield is sure to inspire creativity and spark a love for electronics and programming.
PandaShield Core is easy to use and compatible with the Arduino Uno board. Simply plug the shield into the board, and you're ready to start experimenting and creating. Our shield is also compatible with the Arduino IDE, allowing you to write and upload your own programs.
Note: Arduino Uno, mini servo and I2C OLED display is not included.
Check my other products!
Enter your email address if you'd like to be notified when PandaShield Core | STEM Education Arduino Shield can be shipped to you:
$12.99
$2.99
$12.99
