Essential components, sensors, external connections and more in one compact Arduino shield. Empower your creativity!
Introducing the PandaShield, the ultimate Arduino Uno shield designed specifically for students and beginners in the world of STEM / Arduino. Crafted by an experienced electronic engineer and teacher…
Read More…Introducing the PandaShield, the ultimate Arduino Uno shield designed specifically for students and beginners in the world of STEM / Arduino. Crafted by an experienced electronic engineer and teacher, this compact shield is your all-in-one solution for an immersive and comprehensive Arduino learning experience.
The PandaShield is packed with a range of essential electronic components that will enable students to explore various projects and concepts. It features six 5mm LEDs, perfect for visual feedback and creating stunning light effects. Three buttons offer tactile input for interactive control, while a buzzer adds audio feedback to your projects.
With a built-in potentiometer, students can easily experiment with analog input and learn about voltage division. The included LDR light sensor allows for exploring light-based applications and automation. The RGB LED opens up endless possibilities for color mixing and visual expression.
For environmental sensing, the PandaShield is equipped with the precise and accurate I2C digital temperature sensor, PCT2075. This sensor enables temperature monitoring and integration into climate control projects.
The built-in TCRT5000 infrared sensor module and HC-SR04 ultrasonic distance sensor connection offer opportunities to delve into proximity sensing and obstacle detection. These sensors provide real-world interactivity and expand the range of projects students can create.
The PandaShield goes beyond basic components, with two external mini servo connections for exploring robotics and motion control. It also features two I2C OLED display connections for integrating graphical output into your projects, providing visual feedback and enhancing user interfaces. It also has external HC-06 Bluetooth Module and MPU-6050 gyro/accelerometer sensor connection.
In addition, the shield includes an external universal sensor connection, compatible with various KY type Arduino sensors. This ensures compatibility with a wide range of sensors and expands the versatility of the PandaShield even further.
Designed with careful attention to detail, the PandaShield is compact, sturdy, and easy to use. It provides a safe and convenient platform for students to learn and experiment with Arduino programming and electronics. The shield neatly sits on top of the Arduino Uno, allowing for seamless integration and minimizing setup time.
Whether you're a student, a teacher, or an Arduino enthusiast, the PandaShield is your gateway to the exciting world of Arduino. With its comprehensive range of components and sensors, it offers limitless possibilities for learning, creativity, and innovation.
Note: Arduino Uno and external components (mini servos, HC-SR04, HC-06, MPU-6050 and I2C OLED displays) are not included.
Check my other products!
Enter your email address if you'd like to be notified when PandaShield | Extended Education Arduino Shield can be shipped to you:
$12.99
$2.99
$15.99
$12.99
