Start your PIC microcontroller journey with PICDEV BASE – versatile, user-friendly, and feature-packed.
Introducing PICDEV BASE: Your Ultimate PIC Microcontroller Experimentation Platform Are you an electronics enthusiast, a seasoned embedded systems developer, or a student looking to dive into the fas…
Read More…Introducing PICDEV BASE: Your Ultimate PIC Microcontroller Experimentation Platform
Are you an electronics enthusiast, a seasoned embedded systems developer, or a student looking to dive into the fascinating world of PIC microcontrollers? Look no further than PICDEV BASE - the comprehensive and versatile PIC microcontroller development board designed to empower your creativity, simplify your experiments, and accelerate your learning journey. Whether you're a novice or an expert, PICDEV BASE is your ultimate tool for bringing your PIC-based projects to life.
PICDEV BASE is engineered to be your go-to development board for various Microchip PIC microcontrollers, including the 6-pin PIC10F, 8-pin PIC12F, 14-pin PIC16F, 18-pin PIC16F, 28-pin PIC16F, and 40-pin PIC16F series. This versatility ensures that you have the right platform for any PIC project, from the simplest to the most complex.
We understand that every great project starts with simplicity and ease of use. That's why PICDEV BASE comes with user-friendly features that make experimenting with PIC microcontrollers a breeze:
1. Color-Coded Header Connectors: No more guesswork! Each header connector is equipped with its own color sticker, making it effortless to identify and connect the pins correctly. This feature is perfect for beginners who are just starting their microcontroller journey.
2. Included Jumper Cables: We've included 10 high-quality 10cm male-male jumper cables, so you can jump right into your projects without worrying about sourcing additional components.
3. Prototyping Soldering Area: Explore beyond the microcontroller! PICDEV BASE features a dedicated prototyping soldering area, allowing you to expand your projects, create custom circuits, or attach a mini breadboard for added flexibility.
PICDEV BASE gives you the freedom to choose how you want to power your experiments:
1. PICKIT ICSP: If you prefer in-circuit programming and debugging, simply connect your PICKIT programmer to the dedicated ICSP header.
2. USB Type-C: Conveniently power your board via USB Type-C, ensuring compatibility with a wide range of devices and power sources.
3. Barrel Jack with Voltage Regulation: For external power sources, utilize the barrel jack input, backed by a built-in 5 Volt voltage regulator for stable and reliable performance.
To facilitate your learning and experimentation, PICDEV BASE includes a suite of components and features:
1. LEDs: Get visual feedback with three built-in LEDs. Experiment with lighting patterns, status indicators, or simple visual effects.
2. Potentiometers: Fine-tune your projects with two potentiometers that allow you to control various parameters in real-time.
3. Push Buttons: Interact with your projects using three tactile push buttons, opening up possibilities for user input and interactivity.
4. Piezo Buzzer: Add audible alerts or sound effects to your applications with the integrated piezo buzzer.
PICDEV BASE comes equipped with a 4 MHz crystal oscillator soldered in place, ensuring precise timing for your projects. But we know that customization is key. That's why we've provided an option for you to solder and select your own crystal oscillator, giving you full control over your project's timing requirements.
Ready to take your experimentation to the next level? PICDEV BASE offers an exciting opportunity to enhance your toolkit. Simply add the optional 12F675 and/or 16F628A microcontrollers to your cart, and dive into the world of these specific PIC devices with ease. Plus, you'll have access to downloadable MPLAB XC8 code examples, helping you kickstart your projects and get the most out of your new microcontrollers.
We're not just offering yet another PIC development board; we're inviting you on a journey of exploration, learning, and innovation. With PICDEV BASE, you'll have the tools you need to turn your ideas into reality, learn the ins and outs of PIC microcontrollers, and create projects that leave a lasting impact.
Discover endless possibilities, unleash your creativity, and embark on your PIC microcontroller adventure today with PICDEV BASE. Whether you're a hobbyist, student, or professional, this all-in-one development board is your gateway to a world of endless innovation.
Don't miss out on this opportunity to own the ultimate PIC microcontroller experimentation platform. Order your PICDEV BASE now and join the community of makers, tinkerers, and innovators who are shaping the future, one PIC project at a time.
*Microcontroller Compatibility: 6-pin PIC10F, 8-pin PIC12F, 14-pin PIC16F, 18-pin PIC16F, 28-pin PIC16F, and 40-pin PIC16F series.
*Header Connectors: Color-coded for easy identification.
*Included Jumper Cables: 10 pcs of 10cm male-male cables.
*Power Options: PICKIT ICSP, USB Type-C, and Barrel Jack with built-in 5 Volt voltage regulator.
*Components: 3 LEDs, 2 potentiometers, 3 push buttons, and a piezo buzzer.
*Crystal Oscillator: 4 MHz (soldered) with an option to select your own.
*Expandability: Add 12F675 and/or 16F628A microcontrollers to your order with downloadable code examples.
*Prototyping Area: Dedicated soldering area for custom circuits and mini breadboard compatibility.
Start your PIC microcontroller journey with PICDEV BASE today, and let your imagination soar. Order now and experience the limitless world of possibilities that await you!
Enter your email address if you'd like to be notified when PICDEV BASE | Ultimate PIC Experimentation Board can be shipped to you:
$12.99
$2.99
$15.99
$12.99
$61.99
$46.95
