Experiment USB PIC microcontrollers with PICDEV USB! Versatile, user-friendly, and Arduino form-factor.
Unlock the limitless potential of Microchip PIC microcontrollers with our state-of-the-art development board, the PICDEV USB. Designed for versatility and ease of use, this board is a game-changer fo…
Read More…Unlock the limitless potential of Microchip PIC microcontrollers with our state-of-the-art development board, the PICDEV USB. Designed for versatility and ease of use, this board is a game-changer for both beginners and seasoned developers. With support for various USB-compatible PIC18F series microcontrollers, an Arduino Uno form factor, and a plethora of features, PICDEV USB empowers you to bring your projects to life effortlessly.
The heart of PICDEV USB lies in its compatibility with 20-pin, 28-pin, and 40-pin USB-supported PIC18F series microcontrollers. Whether you're experimenting with the PIC18F4550, PIC18F2550, PIC18F45K50, PIC18F25K50, PIC18F13K50, PIC18F14K50 or any other compatible model, this board has got you covered. Say goodbye to compatibility issues and hello to seamless development.
PICDEV USB adopts the popular Arduino Uno form factor, making it the perfect companion for Arduino prototyping boards. The familiar layout allows you to integrate your PIC projects with ease, utilizing existing Arduino shields and accessories.
Developers love having control over every pin, and we understand that. PICDEV USB provides header connectors for all microcontroller pins, ensuring that you have the flexibility to connect and test your projects with precision.
Reset (MCLR) Button: Resetting your microcontroller is a breeze with the onboard reset button, allowing for quick debugging and testing.
ON LED: A built-in LED indicator provides instant feedback, helping you monitor the status of your board and projects.
Crystal Oscillator Options: PICDEV USB includes an onboard 12 MHz crystal oscillator, but we've also added a footprint for you to solder your own crystal oscillator if needed. A jumper allows you to easily switch between these options, offering optimal flexibility.
Power Select Jumper: Choose between USB power or external 5V power with the power select jumper. It's your choice, ensuring compatibility with various setups.
USB Connector Options: Tailor the board to your needs with optional USB Type-C or classic USB Type-A connectors. Select the one that best suits your project's requirements.
Compatible Microcontrollers: 20-pin, 28-pin, and 40-pin USB-supported PIC18F series microcontrollers. (18F4550, 18F2550, 18F45K50, 18F25K50, 18F13K50, 18F14K50)
Form Factor: Arduino Uno
Pin Access: Header connectors for all microcontroller pins
Onboard Components: Reset (MCLR) button, ON LED, 12 MHz crystal oscillator, power select jumper
USB Connector Options: USB Type-A or USB Type-C (optional)
Additional Option: PIC18F2550 microcontroller available for purchase
Versatility: Supports a wide range of USB-compatible PIC18F series microcontrollers.
User-Friendly: Arduino Uno form factor and complete pin access make it easy for developers of all levels.
Customization: Choose your preferred USB connector type and add optional microcontrollers as needed.
Reliability: High-quality components ensure the board's durability and stability.
Flexibility: Power options, crystal oscillator choices, and extensive pin access cater to a variety of project needs.
Whether you're a hobbyist, student, or professional, PICDEV USB is the ideal platform to turn your PIC microcontroller projects into reality. Its user-friendly design, extensive features, and compatibility with a range of microcontrollers set it apart from the rest.
Unlock the potential of your PIC projects with PICDEV USB. Order yours today and experience a seamless development journey like never before. Join the community of innovators who trust PICDEV USB for their microcontroller needs.
Don't miss out on this opportunity to elevate your projects to new heights. Make PICDEV USB your go-to development board and watch your ideas come to life.
Enter your email address if you'd like to be notified when PICDEV USB - Ultimate DEVKIT for USB supported PIC can be shipped to you:
$12.99
$12.99
$2.99
$15.99
$12.99
