Better use of so called 'breadboard friendly' microcontroller boards
Universal Breakout series are yet another breakout board family for breadboard compatible boards like Arduino Nano, Raspberry Pi Pico or ESP32. It consists of two different board designs; standard an…
Read More…Universal Breakout series are yet another breakout board family for breadboard compatible boards like Arduino Nano, Raspberry Pi Pico or ESP32. It consists of two different board designs; standard and pro.
They makes better use of so called 'breadboard friendly' -but too wide to use in breadboard- microcontroller boards. With Universal Breakout, no more hassle, no more cable mess, but much more breadboard space.
Arduino Nano is breadboard friendly, but ESP32 or NodeMCU is not. They usually takes all the pin space and forces us to use dual breadboard to play with. Universal Breakout series fixes this annoying problem with it's unique design.
Place your microcontroller board to Universal Breakout, then use jumper cables to connect pins to your breadboard. You can also add a 2.54mm 2x40 male header to your PCB and easily connect Universal Breakout Pro with female headers.
Universal Breakout (standard blue PCB model) has classic breakout design and can use nearly all different 'breadboard friendly' boards and allows you to use pins from either side of the breakout board.
Universal Breakout Pro looks similar to standard one, but works completely unique way. It brings all the pins of connected microcontroller board to ONE SIDE! Clean look, no more cable mess. It has 40 pin female connectors at the top side but has two options for the bottom side: Female or Male. Check photos.
Compatible with; Arduino Nano, Nano Every, Nano 33 BLE / BLE Sense, MKR etc. Raspberry Pi Pico NodeMCU ESP8266 ESP32 (30 or 38 pin packages) STM32 BluePill or BlackPill MH-Tiny ATtiny88 And many more!
Check my other products.
Enter your email address if you'd like to be notified when Universal Breakout | Yet Another Arduino Breakout! can be shipped to you:
$12.99
$2.99
$15.99
$12.99
$5.25
$1.00
