Universal IoT board with Sigfox communication
Designed by Micron Things in Hungary
Universal IoT electronics that can be used for various projects. It was originally designed as an electronics scale for beehives. The HX711 AD converter on it allows the connection of a load cell. I…
Read More…Universal IoT electronics that can be used for various projects. It was originally designed as an electronics scale for beehives. The HX711 AD converter on it allows the connection of a load cell. In addition, an external DHT temperature/humidity sensor can be connected to it. The panel also features onboard GPS. Communication is achieved through the ultra-low power Sigfox IoT network. Capable of operating for years on three batteries. This is a truly universal IoT electronics, usable for many tasks.
The board is compatible with Gainta G212 and G212C enclosure boxes. The firmware can be written in the Arduino interface, and the compiled code can be uploaded through the ICSP connector on the panel using an Atmel programmer.
What you need for using Sigfox IoT network
You need to check if you are able to use the Sigfox Network https://www.sigfox.com/coverage/ https://backend.sigfox.com/welcome/coverage (more accurate, an address can be checked) -> A free account must be created
You need to check if you are able to buy a Sigfox Connectivity from your country with 140 messages / day : https://Buy.sigfox.com
You need to buy a contract (a service contract) that will be attached to the module in order to enable its 0G connectivity https://Buy.sigfox.com
Enter your email address if you'd like to be notified when Universal Sigfox IoT electronics can be shipped to you:
