Weller RT Tips Soldering Station / assembled and tested with handle &Cable (for Weller RT compatible tips)
Designed by Mike DIY Store in SloveniaNo shipping info available.
OUT OF STOCK!!! Portable Weller RT Tips Soldering Station: Key Functions: Fast heat up of Weller RT tips to pre-set temperature. Adjustable settings with potentiometer of pre-set temperature up to 40…
Read More…OUT OF STOCK!!! Portable Weller RT Tips Soldering Station: Key Functions:
Fast heat up of Weller RT tips to pre-set temperature. Adjustable settings with potentiometer of pre-set temperature up to 400 deg.C Led display of soldering "Ready Temperature. RGB Led - Green, Red, Blue indicates heating stage and Temp. of Tip. Stand-by temperature sett at 150 deg.C, when RT tip is placed in solder tip stand, Works with any Weller RT(x) type of tip 40-50W and 3.5mm jacks!!
Soldering station is assembled in 3D printed housing and tested. For Weller RT (compatible for WMRP Micro) Micro and Macro Tips (see enclosure Weller RT Tips).
Supply Is including Solder Handle with build in female to female 3.5mm connectors & jacks with cable.
Works with Lipo Battery 11.1V --- for work where there is no wall socket to plug in your Power Supply. I tested it with 11.1V - 3000MAH Ovonic battery!
or Power Supply: Battery 11.1V or 12V 5A switching Supply (could be old computer Power Supply -not in scope of this supply).
Temperature setting range: 0 deg.C to 400 deg.C
Package Include:
1x Station 3D printed with display Cable and handle. (Weller Tip and Power supply not included).
Video: https://youtu.be/hpgbHs6nxrY
Do not hesitate to ask questions!!
For SMD SMT soldering RT Tip(s): RT4 = Tip / Nozzle Width:1.5mm; Tip / Nozzle Style: Chisel; For Use With: Weller WMRP Micro Soldering Pencils; (for Tips see http://si.farnell.com/weller/RT...)
You want only controller assembled & tested (without housing)? - contact me.
Note: Enclosure STL files for your own 3D print https://grabcad.com/library/weller-rt-desk-top-controller-new-version-1
Enter your email address if you'd like to be notified when Portable Soldering iron for Weller RT tips, 12V DC can be shipped to you:
Due to Covid 19 - see Tindie = We are seeing many shipping delays, especially for international orders. Please check individual product pages for details & more info on COVID-19 and Shipping
Milan | Jan. 6, 2021
Timo | July 26, 2020
$165.90
$84.67
$9.69
