Dual-cell Li-Ion BMS module with USB-C charging, I2C monitoring, and dual-cell protection.
MLAB LION2CELL02 - Dual-Cell Li-Ion Battery Management Module What is it? The MLAB LION2CELL02 is a high-efficiency dual-cell battery management system (BMS) designed to charge and protect a two-cell…
Read More…The MLAB LION2CELL02 is a high-efficiency dual-cell battery management system (BMS) designed to charge and protect a two-cell Li-Ion battery stack. Featuring an I2C interface and a USB-C charging port, the LION2CELL02 integrates easily into systems requiring robust power management. The module is compatible with standard USB BC 1.2 sources.
The LION2CELL02 is pre-configured for INR18650MJ1 cells, ensuring optimal performance and battery health.
This module was created to simplify the power management and protection requirements where single-cell Li-Ion battery setups are not enougth. It’s tailored to applications requiring reliable charging, safety, and monitoring features, which are essential in embedded systems like IoT devices, portable instruments, and backup power solutions.
For additional details and configuration options, refer to the datasheets for BQ40Z50-R2 and BQ25792.
Enter your email address if you'd like to be notified when Dual-Cell Li-Ion Battery Management Module can be shipped to you:
$61.00
$5.50
$59.00
$5.20
$31.20
$76.00
$148.00
$24.99
$7.25
