USB-C power source for systems based on 8080A processor with voltage sequencing.
Designed by Tomas Pavlovic in Slovakia
Description I made this power source originally for my PMI-80 KIT. But it can be used for any other board based on 8080A processor. It provides three voltages: +5V, up to 3A (depends on USB adapter)…
Read More…I made this power source originally for my PMI-80 KIT. But it can be used for any other board based on 8080A processor.
Main +5V comes directly from USB adapter and is switched by P-MOSFET. Negative -5V is generated from +5V with switched capacitor circuit TPS60403. And +12V is produced by voltage boost converter TLV61046A.
Outputs +5V and +12V are enabled only when -5V is present. It is requirement for 8080A processor.
The board also contains ON/OFF switch.
The power source comes assembled and tested. You can choose between versions with or without ON/OFF switch. The version without switch powers on as soon as you plug it to the USB adapter.
Power cable is included.
USB cable is not included.
Enter your email address if you'd like to be notified when USB-C power source for 8080A can be shipped to you:
$13.50 $15.00
$5.60 $7.00
$38.95
