This tester detects magnetic pole of guitar pickups or any magnets or locate hidden magnets.
Designed by N-audio in Bulgaria
The N-Audio Magnetic Pole Detector is a valuable tool for luthiers, guitar pickup builders, and anyone involved in electronic guitar repairs. This simple device can detect both the north and south po…
Read More…The N-Audio Magnetic Pole Detector is a valuable tool for luthiers, guitar pickup builders, and anyone involved in electronic guitar repairs. This simple device can detect both the north and south poles of any magnet. Just position its sensor tip near the guitar pickup, and an LED will indicate the magnet’s polarity.
WHY WOULD YOU NEED A MAGNET POLARITY TESTER?
This tool provides the easiest way to determine whether there is hum cancellation when using two single pickups in parallel. If the magnetic poles of two guitar pickups are oriented in opposite directions, they will function as a humbucker. For instance, if you have a set of three Fender Strat pickups, you can swiftly identify the middle pickup – it’s the one with the opposite magnetic pole compared to the other two.
Another scenario where this tool proves essential is when splitting a humbucker and using half of it in parallel with the next pickup on your guitar. You can simply use the part of the humbucker that has the opposite magnetic pole from the next one.
WHY IS THIS TESTER A BETTER CHOICE?
Many magnet polarity testers on the market contain a small neodymium magnet. Its magnetic force is so strong that it could potentially slightly affect the magnetic force of the Alnico magnets commonly used in guitar pickups. In contrast, the N-Audio Magnetic Pole Detector utilizes a precision and much more sensitive sensor that detects magnetic force without altering it. If you wish to preserve the existing tone of your Alnico pickups, this is the best solution!
Magnetic polarity tester for guitar pickups This unit can determine the magnet’s polarity and polarity orientation or locate hidden magnets inside electronic devices. The small sensor tip is designed to fit into narrow spaces, making it useful in various situations. Additionally, because it uses extremely small power when not in use (around 4 microamps), a single CR2032 battery could potentially last for 10 years. Together with the N-audio Guitar Pickup Phase Checker, you will have everything for proper guitar pickup analysis.
SPECIFICATIONS:
Enter your email address if you'd like to be notified when N-audio Magnetic Pole Detector Tester Checker can be shipped to you:
$59.99
$280.00
