30V max Input, DC-DC High-Efficiency Step-down regulator, the perfect drop-in replacement for standard Linear regulators: LM7805,LM317,etc
Designed by NextEVO in Romania
MPDMv7.5 AC Dimmer DevBoard has been released! For special shipping options, custom orders or any other questions/ please feel free to contact me anytime at: nextevone@gmail.com
What is it? A compact, high-efficiency, synchronous step-down DC-DC converter that operates from input voltage sources up to 30V! High converter efficiency is achieved by integrating the current-limi…
Read More…A compact, high-efficiency, synchronous step-down DC-DC converter that operates from input voltage sources up to 30V!
High converter efficiency is achieved by integrating the current-limited, low-resistance, high-speed high-side and low-side switches and associated drive circuitry.
I was looking for a drop-in replacement for some standard linear regulators in existing equipment that heats badly because of to small heatsinks and some poor design. Available space inside was way to small to install a bigger heatsink on most boards.
Impressed by the results, have started using it almost everywhere where I need a good Voltage regulator, so ended up as a standard used regulator module. If you need a nice and stable Voltage Regulator for your projects, you might found it!
Enter your email address if you'd like to be notified when 30V Synchronous step-down DC-DC converter can be shipped to you:
David | Dec. 4, 2016
$18.78
$14.72
$36.98
$27.56
$18.96
$6.95
$5.92
$17.99
$225.00
$5299.00
