IAQ Board is a device for measuring internal air quality. I needed a device for measuring some air quality parameters which is compact, cheap, simple and capable. The device is based on widely availa…
Read More…IAQ Board is a device for measuring internal air quality. I needed a device for measuring some air quality parameters which is compact, cheap, simple and capable. The device is based on widely available and cheap essential components (MCU ESP32 and sensors). The core component is a simple PCB (printed circuit board) that's why I called it IAQ Board. The board integrates all the components in a very small footprint (size of a cigarette box). Firmware is based on ESPHome, which means the device is directly compatile with Home Assistant.
The device have 2 displays and is measuring the following air parameters:
On top of that:
The device is Open Source and all the data to build it yourself is published here. You can find there also full description and manuals.
This IoT device is quite small but capable. Also as it's fully compatible to Home Assistant, you can add it in your home automation for seconds, record the data and do some actions with it (like I am controlling my air purifier with the data from the dust sensor). Also you can tune the firmware, which is quite easy with ESPHome and for example use the LEDs for other purposes (I use the middle LED to illuminate when the air in the kid's room is bad). You have plenty of options.
Unfortunatelly I do not have in stock anymore the fully assembled device. I still sell the fully assembled board and BME280 temperature sensor breakout board (difficult to find now, so I assemble these myself). Also 3D printed case is always available.
Enter your email address if you'd like to be notified when IAQ Board - Internal Air Quality sensor can be shipped to you:
