SBC-like board to carry the Teensy 4.1, providing 4 USB ports, Ethernet, 3.5mm Audio, and a good buck regulator
Designed by Nuclaer Tech in United States of America
What is it? This board turns your Teensy into an SBC, practically speaking. It grants your Teensy four USB ports, high quality audio output, an Ethernet jack, a quality power source, and a 5v-compat…
Read More…This board turns your Teensy into an SBC, practically speaking. It grants your Teensy four USB ports, high quality audio output, an Ethernet jack, a quality power source, and a 5v-compatible bus, all in a SBC-like form factor.
This board is great for building homemade game consoles, synthesizers using PJRC's wonderful audio library, an Arduino-based cyberdeck, etc. This is for anyone who likes the idea of an SBC, but prefers an Arduino environment.
Compatible with USB keyboards, mice, game controllers, USB MIDI keyboards, etc.
Board specifications:
Teensy 4.1 Specifications:
I wanted a highly customizable & capable, but not overly complicated, computer system programmable via Arduino software. This way I have full control of the hardware without writing an OS from scratch, like would be necessary with typical SBCs. This environment is much easier and more stable, as well as more efficient, than systems like a Pi or BeagleBone, however the tradeoff is that you cannot run all the existing software for those systems.
I can, and have, hacked together very messy projects that have the same types of features as this. It is so much better though, to have a board like this that is sturdy, looks good, integrates the exact needed features, is well documented, and can be standardized. This board is the natural next evolution.
Additionally, this is a fun board to use, to see the limits of what is possible with microcontrollers and Arduino boards. This design is so far beyond the original intended scope of the Arduino project, and there is something fun and exciting about it.
This board provides almost all the peripherals of an SBC, however requires no OS to use them. All are accessible from the Arduino environment. To my knowledge, no board has been made previously which integrated all of these features into a single board for the Teensy.
Every unit is hand assembled and tested before shipping. If you have any problem with your board, contact me. I test all USB ports, the audio jack, and power supply. I guarantee that your device works, or your money back.
As each unit is completely assembled by hand, each board will look slightly different, as I am only human.
Only the Teensy 4.1 headers, card connector header, and the I2S header are soldered. The others are left unpopulated, so that permanent wiring may be soldered to them if desired, or some keyed/locking connector. You will receive a board matching the images. Extra headers are not included at this time.
If you ordered a Teensy 4.1 with your board, it will come flashed with the NTIOS software:
Enter your email address if you'd like to be notified when Teensy 4.1 Computer can be shipped to you:
I will ship all days except Sundays, provided the order is placed early enough for me to get it to the post office.
If I'm away from home, I'll usually take some stock with me to ship orders wherever I happen to be.
1-4 | $50.00 |
5-9 | $95.00 |
10-19 | $90.00 |
20-29 | $87.50 |
30-99 | $85.00 |
100+ | $78.00 |
1 Review | 13 Orders
