Micro OLED 0.68 inch WUXGA 1920 x RGB x 1200 high resolution 5000nits high luminance LVDS for AR and VR headsets
Micro OLED Screen 0.68 inch 1920 x RGB x 1200 high-resolution 5000cd/m2 high brightness for Consumer Camera Overview This 0.68 inch Micro OLED Display is a high-quality and technologically advanced d…
Read More…Micro OLED Screen 0.68 inch 1920 x RGB x 1200 high-resolution 5000cd/m2 high brightness for Consumer Camera
Overview
This 0.68 inch Micro OLED Display is a high-quality and technologically advanced displaya micro SI-OLED display, with a high resolution of 1920x1200 pixels and a pixel density of 3135 PPI,this 0.68 Mciro display makes the images and text appearing sharp and vibrant; with high luminance of 5000 nits,high brightness level ensures makes this 0.68 micro screen offer excellent visibility even in challenging lighting conditions, plus its high contrast ratio of 100000:1 (Typ.), this microoled is ideal considered as an outdoor applications and scenarios where sunlight readability is crucial.
This microdisplay also features low power consumption, mini sized, light weight and Thin type,High-speed response, so it is popular used in multiple applications such as AR VR Display, view finders, head mounted displays very small monitors, etc.
0.68 inch Micro Display 1920x1200 parameter: - Diagonal Size:0.68″ - Panel Type:Micro OLED, Si-OLED - Resolution:1920(RGB)×1200 WUXGA - Display Area:9.425 × 12.933 (H×V) mm - Outline Size:12.738×20.34×1.475 (H×V×D) - Frequency:60Hz - Luminance:5000 cd/m² (Typ.) - Contrast Ratio:100000:1 - Interface: LVDS, 61pin - Power Supply:1.8V (logic) 3.3V, -6.6V (analog) - Application: AR headsets;VR AR Display
0.68 inch Micro-OLED Features - Thin and light - Sequential emission - Fast response and High contrast - Idle mode for save power - Support scanning direction selection - Color enhancement - Demo driver board HDMI and USB-C available - Optics lens
Mechanical Drawing
0.68 inch micro oled display Applications:
Packing List: 0.68 inch Micro OLED Display:1pcs HDMI Controller Board: 1 pcs
Enter your email address if you'd like to be notified when Micro AR Display 0.68" 1920x1200 Microdisplay LVDS can be shipped to you:
$558.00
$109.00
$108.00
$149.00
$199.95
$449.00
$539.00
$129.00
$135.00
$105.00
$465.00
$256.00
