OLED Microdisplay 0.39 inch FHD 1024x768 1000cd/m2 micro glasses screen with hdmi driver board
Sold By Display Components
Description The 0.39"Micro OLED Display is a 1.0 cm (type 0.39) diagonal, 1024 (RGB) × 768 dots active matrix color OLED panelmodule using single-crystal silicon transistors. This panel incorporates…
Read More…Description
The 0.39"Micro OLED Display is a 1.0 cm (type 0.39) diagonal, 1024 (RGB) × 768 dots active matrix color OLED panelmodule using single-crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and high definition.
Features:
Orbit supported Input interface that supports parallel RGB 24-bit and YCbCr 16-bit input Specifications
Display Type:OLED Display
Applications:
Packing List:
Enter your email address if you'd like to be notified when Micro OLED Display 0.39" 1024x768 AR VR screen can be shipped to you:
$558.00
$109.00
$108.00
$149.00
$199.95
$449.00
$539.00
$129.00
