0.23 inch Micro OLED Display 640(RGB)X400 with CVBS Controller Board for AR/VR
Description: The 0.23" Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 dots active matrix color OLED panel module using single-crystal silicon transistors. This panel incorporate…
Read More…Description:
The 0.23" Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 dots active matrix color OLED panel module using single-crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and high definition.
The full kit:Display (800 nits)+CVBS Driver Board+Prism (Optional)
Specifications
Applications:
Features:
Enter your email address if you'd like to be notified when 0.23 inch Micro AMOLED Display 640x400 800nits can be shipped to you:
$75.00
$574.00
$135.00
$238.00
$129.48
$479.00
$235.00
$275.00
$275.00
$185.00
$289.50
$258.99
