0.23" Microdisplay 640x400 OLED Module 3000 nits with CVBS Controller Board for AR VR
Description The 0.23" Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 dots active matrix color OLED panel module using single-crystal silicon transistors. This panel incorporates…
Read More…Description
The 0.23" Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 dots active matrix color OLED panel module using single-crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and high definition.
The full kit:Display(3000 nits)+CVBS Controller Board+Prism
Specifications:
Applications:
Features:
Enter your email address if you'd like to be notified when 0.23" inch Micro AR VR OLED Display 640x400 can be shipped to you:
$75.00
$574.00
$135.00
$238.00
$129.48
$479.00
$235.00
$275.00
$238.00
$275.00
$326.00
$255.00
