Micro OLED 0.23 inch 640x400 High-resolution 5000cd/m2 90Hz MIPI Microdisplay for VR Headset
5000nits high-luminance micro oled 0.23 inch 640x400 high-resolution micro display for AR glasses/VR Headsets. Description: The Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 do…
Read More…5000nits high-luminance micro oled 0.23 inch 640x400 high-resolution micro display for AR glasses/VR Headsets.
Description:
The Micro OLED Display is a 0.6 cm (type 0.23) diagonal, 640 (RGB) × 400 dots high resolution colorful Micro AMOLED Screen, based on single-crystal silicon transistors OLED technology, this microoled offers multiple features in high brightness up to 5000nits, supporting frame rate up to 90Hz, high contrast, small-sized, high-Definition and low power consumption, which makes this micro display be used in various fields in head?mounted displays, AR glasses, VR headsets, View finders, etc.
There is designed display adapter HDMI controller board for demo.
0.23 inch Micro OLED Screen 640x400 parameter:
Adapter HDMI Driver board for the 0.23" Micro-oled Display :
Packing Details:
Enter your email address if you'd like to be notified when 0.23" Micro OLED Screen 640x400 5000nits 90Hz can be shipped to you:
$75.00
$574.00
$135.00
$238.00
$129.48
$479.00
$235.00
$275.00
$135.00
$479.00
$255.97
$88.59
