0.5 inch Micro OLED Display 1024x768 with AV Controller Board for VR Headsets
Description: The 0.5" micro OLED Display is a 1.3 cm (type 0.5) diagonal, 1024 × 768 dots active matrix color OLED panel module using single crystal silicon transistors. This panel incorporates pane…
Read More…Description:
The 0.5" micro OLED Display is a 1.3 cm (type 0.5) diagonal, 1024 × 768 dots active matrix color OLED panel module using single crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and highdefinition. It enables full color display in NTSC/PAL progressive system.
The full display kit:Display+VA/CVBS Driver Board(optional)+Optics (optional)
Specifications
Applications:
Features:
Enter your email address if you'd like to be notified when 0.5" Micro OLED Display 1024x768 for VR Headsets can be shipped to you:
$479.00
$88.59
$135.00
$129.48
$238.00
$274.98
$528.00
$185.00
$165.00
$275.00
$255.00
$499.00
