Micro OLED Display 0.5 inch 1024x768 with VGA Controller Board
Description: The 0.5" micro OLED Display is a 1.3 cm (type 0.5) diagonal, 1024 × 768 dots active matrix color OLED panel module using single crystal silicon transistors. This panel incorporates panel…
Read More…Description:
The 0.5" micro OLED Display is a 1.3 cm (type 0.5) diagonal, 1024 × 768 dots active matrix color OLED panel module using single crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and highdefinition. It enables full color display in NTSC/PAL progressive system.
The full display kit:Display+VGA Driver Board(optional)+Optics (optional)
Specifications
Applications:
Features:
Enter your email address if you'd like to be notified when Microdisplay 0.5 inch OLED AR VR Display 1024x768 can be shipped to you:
$574.00
$465.00
$135.00
$238.00
$129.48
$274.98
$479.00
$235.00
$528.00
$275.00
$499.00
$258.99
