0.39 inch Microdisplay 1024x768 OLED Display with CVBS Controller Board for AR / helmet display
Description The 0.39"Micro OLED Display is a 1.0 cm (type 0.39) diagonal, 1024 (RGB) × 768 dots active matrix color OLED panelmodule using single-crystal silicon transistors. This panel incorporates …
Read More…Description
The 0.39"Micro OLED Display is a 1.0 cm (type 0.39) diagonal, 1024 (RGB) × 768 dots active matrix color OLED panelmodule using single-crystal silicon transistors. This panel incorporates panel driver and logic driver, and realizes small size, light weight and high definition.
Specifications
Applications:
Features:
Enter your email address if you'd like to be notified when OLED 0.39 inch AR VR Microdisplay 1024x768 can be shipped to you:
$75.00
$574.00
$135.00
$238.00
$129.48
$479.00
$235.00
$275.00
$185.00
$528.00
$526.00
$335.00
