Digital Vacuum Sync Gauges for motorcycle/carb engine maintenance 12 bit resolution and semi autotune
Designed by Origin_V01D in United Kingdom
This diagnostic tool connects to carbs/throttle bodies of multi carb/throttle engines and allows you to quickly and easily synchronise your engine faster and more precisely than methods available now…
Read More…this diagnostic tool connects to carbs/throttle bodies of multi carb/throttle engines and allows you to quickly and easily synchronise your engine faster and more precisely than methods available now
the importance of synchronised fuel intake systems especially on performance engines not only help with producing their peak power but also allow for greater fuel economy which is something today we all thinking about
features include:
V2 includes better sensors with wider range upto 100Kpa so perfect for Turbo/Supercharged application
ease of use - just plug in turn on and tune, no needles to zero, no valves to adjust V2 no filters required!
1100mah lithium ion battery - just use the usb micro port to charge between uses, the unit lasts several hours on a single charge
large 4 inch Colour TFT - the screen allows bigger font and wide viewing angle which is especially helpful when trying to locate and turn screws inside an engine bay
12 bit resolution - using cutting edge sensors and the fantastic ESP32 you get more readings than ever before possible
V2 has 5 pressure measurements - kPa, mmHg, inHg, PSI and kgcm2
multi sample smoothing - Smoother data readings for easier calibration, no more jumping analog needles or inconsistent results
auto calibration - upon every startup the sensors calibrate themselves to provide the most accuracy when taking a reading
temperature compensation - from -40 to +125 degrees C
stable sensor readings - less than 2% drift from 0-85 degrees C
semi auto tune - the red bar graph will flash green when two adjacent readings are within 1-2% of each other, meaning you can clearly and easily see on the display when your readings are becoming more in tune, the faster the green flashing the closer in sync they are as well as the bars naturally becoming more aligned
the unit comes in a 3d printed case and comes with a range of silicon hoses that you can fit to connect to most carb spigots / nipples
can post worldwide due to light weight
Enter your email address if you'd like to be notified when V2 Digital Vacuum Sync Gauges for Carbs/Throttle can be shipped to you:
Lucio | Oct. 30, 2023
$152.00
$349.00
