Rechargeable lithium polymer (LiPo) battery, genuine JST-PHR-2P connector, integrated PCB for charge/discharge protection
Sold By 64seconds
This is a rechargeable lithium polymer (LiPo) prismatic battery with a genuine JST-PHR-2P connector. The connector is "reverse wired", meaning that battery + & - are connected to pin 1 (red wire) & p…
Read More…This is a rechargeable lithium polymer (LiPo) prismatic battery with a genuine JST-PHR-2P connector. The connector is "reverse wired", meaning that battery + & - are connected to pin 1 (red wire) & pin 2 (black wire), respectively. The integrated PCB protects against: 1. applying too much voltage when charging, 2. demanding too much current when discharging, for example, if the output is a short circuit, and 3. deep discharge - the load is disconnected once the battery voltage reaches 3.0 V to prevent damage.
We use lithium batteries in our own products, in sufficient volume to procure directly from the factory, so we can pass on our cost savings to people who need smaller quantities.
We have used PKCell batteries in our own products for several years. They are high-quality construction, reliable, and have genuine JST connectors, which means they connect in a rugged and secure fashion.
Enter your email address if you'd like to be notified when Lithium Polymer Prismatic - 3.7V, 1,200 mA-hr can be shipped to you:
1-9 | $6.00 |
10-24 | $5.50 |
25+ | $5.00 |
