ESP8266 Adapter Board For Flipper Zero
Designed by PCB Studios in United States of AmericaThis product is no longer available for sale.
$45.99
$69.99
This is a GPIO board for the flipper zero that allows you to add an ESP8266 board programmed with the correct code so that you can deauth networks You can either purchase a board with it or you can u…
Read More…This is a GPIO board for the flipper zero that allows you to add an ESP8266 board programmed with the correct code so that you can deauth networks
You can either purchase a board with it or you can use your own
The board is running a modified version of SpacehuhnTechs ESP8266 Deauther from SequoiaSan
This software allows you to easily perform a variety of actions to test 802.11 wireless networks by using an inexpensive ESP8266 WiFi SoC (System On A Chip).
The main feature, the deauthentication attack, is used to disconnect devices from their WiFi network.
Before you can use this module you need to add the app to your flipper zero. The app is already installed on most custom firmwares such as Rougemaster and Xtreme. To get to the app go to Apps>GPIO>[ESP8266] Deauther. If you do not have the app already installed go to the source code and follow the steps on github otherwise follow the steps below.
Instructions to use the board: https://github.com/suitablebat9/Flipper-Zero-ESP8266-Deauther/blob/main/ESP8266%20Deauther%20Instructions.pdf
Note: This only works on 2.4ghz networks NOT 5ghz
DISCLAIMER
Please use this tool responsibly and do not use it against others without their permission!
Please check the legal regulations in your country before using it.
I don't take any responsibility for what you do with this board/code.
$24.99
$14.99
$3.99
$33.60
$24.99
