Dip Switch Type-C Trigger Module
Designed by PCB Studios in United States of America
This module supports PD/QC protocol and up to 100W. High current protection, anti-static protection. Input Voltage: 4-21V Output Voltage:5V/9V/12V/15/20V current: 5A (maximum) Size: 25.7mm * 11mm Up …
Read More…This module supports PD/QC protocol and up to 100W.
Size: 25.7mm * 11mm
Up to 100W at 20V 5A
Input voltage needs to be higher than output voltage
Input overvoltage and undervoltage protection
Input overcurrent protection
Output overcurrent and short circuit protection overall
If you want wires soldered you MUST select without screw terminals
Set the voltage on the DIP switch according to the bottom of the board.
9V 0-0-1
12V 0-1-0
15V 0-1-1
20V 1-0-0
Enter your email address if you'd like to be notified when Type-C PD Decoy Dip Switch Trigger Module can be shipped to you:
$3.99
$28.00
