Settable logic gates, with 8 jumper you can set it to any logic gate, AND, NAND, XOR, etc. But it can also act as a 8 channel multiplexer.
Designed by Peet's Electronics Shop in NetherlandsNo shipping info available.
What is it? It's a multi tool that can be handy with development, or if you want do some simple logic without knowledge of programming. With some jumper you can do all kind of automation. Just for f…
Read More…What is it?
It's a multi tool that can be handy with development, or if you want do some simple logic without knowledge of programming. With some jumper you can do all kind of automation. Just for fun and for learning about all kinds of logic gates without buying all the chips and building the circuits for it.
Why did you make it?
I often need some clue logic or inverter when developing products or just playing with some electronics. It was a hassle searching for the right chip and setting up a circuit for the logic gate.
What makes it special?
It's multi-purpose and can act as any logic gate or as a multiplexer/demultiplexer when you need some more output or input.
SMD parts are pre-soldered The pin headers must be soldered yourself PCB get packaged in anti static bag
Enter your email address if you'd like to be notified when Settable logic gates / multiplexer can be shipped to you:
I check the Tindie store a couple of times a week. I try to ship on Wednesdays and Saturdays, and if I have time also in between, but in general it will take 2-3 days. All items that are listed as stock are ready for shipping.
If there are optional parts that need to be soldered on the item(s) it can take 1-2 days longer before I send the package(s).
I will make pictures of the package(s) before I send the package(s ) and will inform you with picture(s) when I send the package.
Product: (4.00)
Phil | Sept. 5, 2018
$26.00
$126.29
